Hi
I have got the TMPGEnc and found 'use multi-thread' in the setting and wonder what this does and if i should use it what settings should i use.
If you fill out your computer profile you might get a better answer. It all depends on your hardware.
"Art is making something out of nothing and selling it." - Frank Zappa -
Check here: http://dvd-hq.info/Compression.html
Scan down to the bottom and "Other Options". Multithreading is good for dual CPU's or Pentium 4's so in your case it should be off."Art is making something out of nothing and selling it." - Frank Zappa
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
