I'm trying to backup Chappelle's Show Season one. It is a 2 disc set. I want to dump all the extras and menus, leaving just the episodes so I get the best quality. I've used DVD Decryptor to rip both DVD's to my HD. How do I reauthor those files to put the episodes onto 3 DVD-R's rather than the original two? Thanks
Kyle
quick and easy way is to use DVD shrink. use the open files button instead of open disc, and locate the folder for disc one. select re-author and then drop as many episodes you can fit into the DVD box on the left. hit backup to ouput these files to a folder on your hard drive. do the same for your second disc, except you'll also need to open another instance of shrink with the original disc two selected. you can then drag the required eps from original disc two along with however many from original disc one to make disc two. now just make disc three from the copy of shrink that's selected original disc two.
make sense?
Set default MKV size in DVDfab for a 4.37GB DVD disc?
By iamkatpeeler in forum Authoring (Blu-ray)Replies: 7Last Post: 24th Apr 2011, 09:59 -
NO DISC on set-top players - dvd replication
By wzt in forum Authoring (DVD)Replies: 16Last Post: 25th Sep 2009, 10:15 -
How to make one .avi from a two disc set?
By TheMoreYouKnow in forum Newbie / General discussionsReplies: 8Last Post: 24th Sep 2009, 08:52 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 15:59 -
Ripping 2 disc set with Fairuse Wizard 2
By acid_burn in forum DVD RippingReplies: 2Last Post: 25th Mar 2008, 14:12
