Well my computer shouldn't be the problem I don't think. I have an AMD Athlon XP 2600 with 768 MB DDR Ram. I have been capturing AVI Uncompressed with MGI Videowave with 720x480 resolution. Then, when i print to my DV camera through one of my editing programs, its kind of choppy, not really noticeable, but still noticeable, especially when I edit a slow motion effect. All some of the clips have a horizontal line type of distortion to them. Anyone have any ideas on how I can capture perfectly what the tape shows on TV, edit it, and then send it back to the tape in the same condition? Any help would be much appreciated.
i really doubt you are capturing uncompressed video ... unless you are capturing to a scsi raid system ..
it's only be 29 megs a second.....
You're not very clear, is your source VHS or DV?
Problems with analog cable capture
By billqs in forum Capturing and VCRReplies: 2Last Post: 6th Apr 2009, 15:31 -
Analog capture poll
By goggy59 in forum Capturing and VCRReplies: 3Last Post: 4th Jan 2009, 20:28 -
new system capture card analog and dv
By rikit in forum Capturing and VCRReplies: 0Last Post: 27th Nov 2007, 20:44 -
Analog video capture in Vista.
By Frogged in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2007, 10:47 -
Analog to Avi capture card
By ni-mh in forum Capturing and VCRReplies: 0Last Post: 25th Jul 2007, 17:16
