major -
I'm new to OS X and am not sure hoe to drive the 0.7.8 version of VCDImage.
Unzipped, I get a folder named 'usr' and inside that, in the 'bin' folder, I've got generic icons for the apps.
In OS X, which app should I choose to open 'vcdimager'?
Could you point me in the right direction?
Thanks!
Dave
if you're new to Unix maybe you will prefer to use http://www.sbpr.a.se/vcdtoolsx/ which includes VCDImager but wraps it into a point and click GUI so you don't have to know Unix.
Otherwise VCDImager operates in command line mode. You need to open the terminal, copy the vcdimager executable files into /usr/local/bin and then run them in command line mode conforming to user manuals.
Where is the Major... ??
By moon47usaco in forum ffmpegX general discussionReplies: 2Last Post: 12th Aug 2010, 12:22 -
Have major problems with dvdauthorgui
By blue-eyed in forum Authoring (DVD)Replies: 1Last Post: 25th Apr 2008, 23:05 -
Need Major help from an expert!
By jbartosh in forum MediaReplies: 38Last Post: 23rd Oct 2007, 12:45 -
Major Problem with AVI
By thepcpitstop in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 6th Jul 2007, 11:49 -
major problem
By Antitrust19 in forum ComputerReplies: 6Last Post: 28th May 2007, 08:30
