im having problems playing a wmv file that i dled it from my schools website, when i play it in windows media player(version 9 and older versions also) i get this Error ID = 0xC00D1199, Condition ID = 0x00000000,Cannot play the file. any suggestions on how i can fix that?
or should i try converting the wmv file to something else, it doesnt matter rm, avi, mpg anything just as long as it'll play, any programs that can help me do that? converting it to a rm or avi would be good because the file is 230mb and converting that to mpg would take a while.
thanks in advance
Results 1 to 10 of 10
Did you try to lookup the error on Microsoft's web site or even on google?
yep i wrote on the newsgroup and everything and got no help on fixing the error, knowing microsoft they probably dont even know how to fix it its their own file too. any suggestions?
Try loading it with a trial version of TMPGEnc Plus! When the Open box comes up, select all files, and select the wmv file.
Hello. -
hey, i just dled TMPGenc Plus, same thing happened with the older version of TMPGenc i have. you said when the open box comes up select all files and choose WMV file right? which open box are you refering to? the wizard that automatically pops up, or MPEG tools or the main window that says Video Source, Audio Source, Output? i tried every open option available that opens a file but it always says illegal stream.
thanks in advance! -
And in your Environmental settings you do have Direct Show as the highest priority, right? You never mentioned "illegal stream" errors until the last post, so we had no idea. I hope you're not leaving anything else out.
Hello. -
hey tommy, lol no i dont think im leaving anything else out. its just that when i play the wmv on windows media it gives an error that it cannot play the file, but when i try to use TMPGenc with it, it gives me illegal stream errors. i just changed DirectShow to the highest prority its up on top, now do i select the wmv on the Video Source in the main screen? are there any other properties i should be changing also?
btw when i selected my wmv in the video source i got a error that said it cannot be opened or supported. i guess this file is corrupted to begin with right -
If you had searched Google for "error ID = 0xC00D1199"
You would have discovered that there is a patch from MS that is suspose
to fix this.
http://support.microsoft.com/?kbid=816044 -
yea i saw this link when i was looking through their newgroups, but its for ASF files, and the symtoms that they list doesnt match mines so i didnt even both with dling that patch.
MKV files with embedde subtitles HELPPP
By Asesinato in forum SubtitleReplies: 3Last Post: 25th Dec 2011, 20:05 -
helppp me about a choice 4 Live Video Streaming
By stijev in forum Video Streaming DownloadingReplies: 0Last Post: 2nd Nov 2009, 16:14 -
Question about FFMPEG WMV conversion
By shaktar in forum Video ConversionReplies: 2Last Post: 6th Feb 2009, 08:46 -
wmv conversion problem
By uglijimus in forum Video ConversionReplies: 6Last Post: 11th Jan 2009, 12:30 -
Bitrate question for Avi to Wmv conversion w/ Windows Media Encoder
By Gonz0ne in forum Video ConversionReplies: 5Last Post: 6th Jan 2008, 08:19
