I own a JVC Digital video GR-DVL820U and I just capture about 19gig of home video into my comp. I was really amazed by this b/c this is my frist time doing this. i want to convert it to a vcd and use dvd author to burn it to a dvd. is this a good idea? approx how big will the vcd be if i convert it?
Computer Spec:
winxp pro, 2.4ghz, 768mb ram, 100gb -
If you are burning it to a DVD then you are creating a VCD resolution DVD. DVD has three basic resolutions: 1/4 DVD (VCD), 1/2 DVD and full DVD. If you have DV footage then it would be better to convert to 1/2 DVD resolution which is 352x480 for NTSC and 352x576 for PAL. You should be able to get 3 hours of decent quality on a DVD using a bitrate of 3000 Kbps.
BTW, the size of your DV-AVI has nothing to do with the size of the mpeg. 19 GB is about 1 1/2 hr of DV footage."Art is making something out of nothing and selling it." - Frank Zappa
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 14:19 -
Font size will not change size
By pgwillin in forum ffmpegX general discussionReplies: 9Last Post: 8th Jan 2011, 15:04 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 09:46 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 05:14
