I have used CCE, Main Concept, Canopus Procoder E xpress & TMPEG. They are all slow when doing best quality. I am looking to upgrade my PC. What is the usual limiting factor for speed with these encoders? Is it CPU frequency, Bus speed, Quantity of RAM, Speed of RAM or something else?
Originally Posted by pharries
Basically you should have Windows 2000 or WinXP with 512MB RAM and the fastest CPU you can buy since that is the biggest bottle-neck with software MPEG encoders.
BTW I find that AviSynth used with CCE is pretty darn fast at least much faster than TMPGEnc.
First, it's the pure horsepower of the CPU. In most cases, more mega/giga hertz will always be faster.
But teaming a 3gig CPU with 128mb of 133mhz SDRAM will starve the cpu. So next would be bus speed and memory speed.
The newest 800mhz bus speed P4s with 400mhz DDR memory is a good combo.
I, myself, am stuck between getting a dual AMD XP or a dual Xeon setup to replace my current dual PIII 600 setup. Both will end up costing about the same price for the same speeds, but I like the features of the XP mobos a little more. -
It's all about CPU
256MB Ram is enough, 512 helps, 128MB do the job done but ain't a smart move with w2k / winXP
W2K IMHO is a better choice than WinXP, ecpecially when you use AMD CPUs
Limiting the amount of zooming After Effects is doing during stabilization?
By kingmustard123 in forum EditingReplies: 3Last Post: 3rd Jul 2011, 10:12 -
Bigger factor for blockiness/compression artifcats
By pannayar in forum Newbie / General discussionsReplies: 4Last Post: 6th Sep 2008, 07:47 -
Capture Cards with hardware compression to Xvid/Divx?
By quantass in forum Capturing and VCRReplies: 7Last Post: 31st Aug 2008, 19:50 -
What is a scale factor?
By rocky12 in forum Newbie / General discussionsReplies: 47Last Post: 22nd Jul 2008, 14:34 -
Is YouTube using some kind of audio compression/limiting now?
By brassplyer in forum Video Streaming DownloadingReplies: 1Last Post: 11th Jul 2008, 06:28
