ok, i captured one of my VHS onto the computer and im hoping to transfer that to a DVDr. Altogheter, the 10 avi files that were split apart when capturing are about 21 gigs. So first i tried to join all the parts together using Virtualdub. I simply appended the parts and saved the movie with direct stream copy on video and audio. It worked fine and the resulting avi was 25 gigs. The audio and the video were good at the beginning until later on in the movie, the audio and video gets out of synch. Anybody know how to correct this?
The proper use of Goldwave to fix this, is outlined here: http://club.cdfreaks.com/showthread.php?s=&threadid=59487
Cheers, Jim
My DVDLab Guides -
The FREE way:
Before making any changes, like cutting out unwanted sections:
Open your AVI in VirtualDub.
Under "Video" select "Frame Rate".
In "Source rate adjustment" select "Change so video and audio durations match, OK.
Under "Video" select "Direct stream copy".
Under "File" select "Save as AVI".
Save to the other hard drive.
Check your new AVI's file info and you will see that the audio and video are the same length.
Go ahead and cut the unwanted sections.
Save back to the original hard drive making sure the video "Direct stream copy is still checked".
This will probably produce an AVI with a frame rate of 29.968 or thereabouts which is still within the normal parameters of most encoding programs (TMPGEnc has no problems with it). -
thanks for your help "almost human", but i dont think you understand what im doing. Im not trying to edit the avis. I want to put the avis together because they got split apart when it was captured. So do i append the avis and then select video and so forth or do i do that with each avi before i append them.
The split AVI's need to be merged back into a single, VirtualDub will only work with a single. Use the same program you captured with to recreate the sequence of clips in order, then output save as an AVI file. Depending on the program you used, you might have to tell it to "make settings match file type" to keep from re-encoding. After this then follow my previous suggested fix.
Originally Posted by Almost Human
Virtualdub has already "worked" with his multiple clips, and joined them, that's not the problem.
Progressive audio desync is a problem, and I linked to a guide that works great for resyncing audio.
Once it's been checked in virtualdub (no need to rejoin the streams), the files can be encoded together or separate. Join during encoding, or authoring.
To check audio sync in vdub, load the avi video, then select Audio, wave audio. Advance to near the end of the file, and check for sync by hitting the Play 0 arrow (output).Cheers, Jim
My DVDLab Guides
DGIndex makes Video out of sync with Audio - please help!
By VideoFanatic in forum Video ConversionReplies: 10Last Post: 16th Oct 2011, 16:53 -
Video and audio are out of synch when authored
By edong in forum Authoring (Blu-ray)Replies: 2Last Post: 9th Dec 2009, 23:39 -
AVCHD audio and video are out of synch
By edong in forum Authoring (Blu-ray)Replies: 0Last Post: 21st Jul 2009, 00:55 -
Windows movie maker makes the audio and video out of sync
By DaneClark in forum EditingReplies: 4Last Post: 9th Jul 2009, 20:45 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 12th Jan 2008, 23:47
