i cannot open this avi file.. when i open it wit tmpgenc it says "cannot open or unsupported" so i tried this
that didnt work.Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 2 or to the top of the plugin-list and try reopen the video.
If that does not help be sure that you have installed DivX or XviD or MPG2 or DV Codecs, read here how to identify what codecs you need.
And when i try this
avicodec would not even recognize the file this goes the same with virtual dub...Use AVIcodec to identify the video format and audio format of almost any video source. AVIcodec will tell you what video codecs or filters you need to be able to play it on your computer. It will also give you the the video and audio properties/details/information such as resolution, framerate(fps) and bitrate(for example to check if your source is PAL or NTSC, NTSC=29,97/23,976fps and PAL=25fps).
1. Open the video source
2. Check what video and audio codecs it requires. (VCD do not require any codec but SVCD/DVD requires a MPEG2 Codec or software DVD Player)
Then download and install the required codecs. You find some codecs here or use google.com.
my installed filters that the time were.. xvid, ffdshow, direct show ogg vorbis, divx 5.11 pro, ac3 filter, and AC3ACM v0.7....
analyzed this wit gspot and get this
So Close AC3 cd1.avi
Size: 701 MB (or 718,042 KB or 735,275,008 bytes)
Type: Non-AVI File - Type Unknown.
any help???
Results 1 to 1 of 1
Acrobat Pro X not opening files within an IE window
By Toastie in forum ComputerReplies: 1Last Post: 22nd May 2011, 13:49 -
Opening video files from computer
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 8th Jan 2011, 17:55 -
Opening files in Graph Edit
By tb582 in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2009, 13:27 -
Opening Multiple files in Dr. Divx
By clawg in forum Video ConversionReplies: 0Last Post: 8th Apr 2008, 13:04 -
opening .z files on a mac?
By jwnulife in forum MacReplies: 1Last Post: 20th Mar 2008, 09:53
