I followed the guide:
https://www.videohelp.com/forum/userguides/120013.php
Unless I'm missing something, only 1 mpeg can be used. I was going to try making a dvd using two 1-hr mpeg captures but I guess it won't work right? Do they intend to add this (very basic) feature in the near future? I guess i can't complain though, it is freeware afterall
There's an inexpensive trialware program called ReJump Movie Joiner that's supposed to join multiple video and/or audio files into one large file. It's only $19 and you can use it unregistered (three file limit). I have not tried it, but it seems very simple to use.
Here's a free file joiner that should work (thanks to ChrissyBoy):
http://www.peretek.com/sfj.php -
where does it say only mpeg1 in that guide???
i would use another authoring guide instead of joining video, if you want a free try dvdauthorgui. -
It doesn't say it, but when i load the file, it only lets me load one (as far as I can tell). but I'll check out that other method, thanks
I need IFOedit for Mac
By bryceguy in forum MacReplies: 7Last Post: 14th Dec 2011, 11:45 -
Changing a 4:3 menu to 16:9 using ifoedit
By NBninja8 in forum Authoring (DVD)Replies: 4Last Post: 20th Jan 2009, 20:11 -
ifoedit question
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 03:10 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 00:42 -
adding CC with ifoedit
By loster in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 19:15
