i just converted a ntsc xvid to dvd ntsc using tmpgenc plus, its seems fine playin back using windvd but when playing back on both my stand alones it has a very bad blur, it's like a blur with straight lines in it, it happens at the slightest movement too, any help please. oh it does it when it changes scene in the film as well...
"I know it seems hards sometimes but remember 1 thing, though every dark night there's a brighter day after that, so no matter how hard it get, stick ya chest out, keep ya head up and handle it"
"politicians and hypocrits dont wanna listen" -
What resolution and bitrate did you use?
Cheers, Jim
My DVDLab Guides -
Reason #812 why every time I see people saying that XVid is "better" than DIVX, I laugh and point.
It may very well simply be that the video you're trying to convert, and your particular XVid codec... don't get along all that well.
- Gurm -
There is nothing wrong with Xvid codeks, at least i never had problems, even if Xvid has been the codek of choice for my avi files for a long time now. Please note that post concerning Xvid problems are when using tmpgenc, the holy cow some people are afraid to say anything bad about. gurm, you better look elsewhere before blaming xvid, or explain why xvid is more trouble for you than for most others.
I agree with thor300, anytime someone instantly jumps on a program or codec (Xvid in this instance) infering that it is a piece of crap, when many people use it happily, just says something about the capability of that person.
@TheRealDeal blury with straight lines where there is motion... sure sounds like deinterlace gone bad to me. Can you say for sure that it is not a deinterlacing problem? Also, is this an Xvid you created (if so what settings did you use) or one that you DLed from who knows where?
-Suntan -
na i d/l it what i wa doin was tryna convert to dvd btu had the problems, but i wa playin with diff templates i used ntsc vcd and it seems fine i just changed the sound to 48000 before i clocked convert and used tmpgenc dvd author and it seems fine, just that then i used a dvd template it was being the way it was, noticed i loaded pal vcd and it did the same blur thing, but ntsc vcd works but not ntsc dvd... well the convert to vcd works for me so guess i sorted my self out...
Hey thor300, sure does sound like Xvid is causing all the problems, huh... 8)
-Suntan
Converting xvid movies
By SJRSMITH1 in forum DVD RippingReplies: 1Last Post: 14th Jul 2011, 00:26 -
xvid to dvd converting help
By victoriabears in forum Video ConversionReplies: 12Last Post: 15th Nov 2010, 21:00 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
Error Converting to Xvid
By Davop in forum DVD RippingReplies: 2Last Post: 23rd Jan 2010, 06:06 -
Converting .Xvid to DVD.... Please
By Galosat in forum Authoring (DVD)Replies: 2Last Post: 18th Sep 2007, 16:10
