Hi All,
I have a movie file that shows the following info in G-Spot:
Video = DivX 5.0
Audio = MP3 VBR
Render Video Path = AVI Splitter=>DivX Decoder Filter=>Subtitle Mixer.
Rende Audio Path = AVI Splitter=>Moonlight Odio=>Morgan Stream..
This movie runs fine in WMP v6.4 and v9. It shows in properties (WMP v9) video codec = Subtitle Mixer)
I create a simple aviscript (avisynth v2.54) to open the video and save as Movie.avs:
video = "C:\TEST\DOD.avi"
AviSource(video)
When I run this .avs file in WMP, I can hear the sound but the video is all black. I looked at the video codec in properties in WMP v9 and it is blank. I tried to open also in VirtualDub and I get flashing green screen.
I also tried and added this line,
ConvertToYUY2()
to the bottom of the script, but got the same result. Please help if anyone knows what the problem is. Thanks in advance!
Load file in virtualdubmod and use direct stream copy to save video as avi-save audio as wav file
load avi file with avisource and wav file with wavsource-use audiodub for muxing-think your avisynth script will work
you can try adding
EnsureVBRMP3Sync()
before trying above. -
First, thanks for the quick reply. However, I tried both ways and still it did not work.
#Script 1
AviSource(video)
EnsureVBRMP3Sync()
ConvertToYUY2()
#Result = Black screen
#Script 2
video = AviSource("c:\TEST\DOD.avi")
audio = WavSource("c:\TEST\DOD.wav")
AudioDub(video, audio)
EnsureVBRMP3Sync()
#Result = Shows like 1 frame of the video then turns green for a few seconds then flash 1 frame again. And it keeps doing this.
#Script 3
EnsureVBRMP3Sync()
ConvertToYUY2()
#Result = WMP v6.4 attempts to download some codecs then it said unable to download an appropriate decompressor, and the video plays showing black screen.
I noticed that when I open the 'watchable' avi file itself with VDub, the decompressor in the 'File Information...' is 'DivX Pro 5.0.2' codec. When I open the 'green screen' avs script, the codec for script 2 (w/out the 'ConvertToYUY2()') is 'XVID MPEG4' and for script 3 it is 'YUV 4:2:2 (YUY2)'
Any other suggestions, anyone? Thanks in advance for the help! -
if this is considered newbie conversion - MAN, do I have a LONNNNGGGGG way to do
try directshowsource instead of avisource. Also make sure you have the divx codec installed on your computer.
Should i use and avisynth script for Dv ?
By smartel in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2012, 08:29 -
Need Help with My AviSynth Script
By Enkidu in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2011, 21:37 -
Avisynth Script Help
By jamhat in forum Video ConversionReplies: 2Last Post: 29th Nov 2009, 06:13 -
Avisynth script
By daz2712 in forum Video ConversionReplies: 2Last Post: 19th Aug 2009, 11:08 -
avisynth script
By magenta2007 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 25th Sep 2007, 11:29
