Hello all,
Router questions here ...
I presently have dsl service over a pppoe connection with a Gnet IP0006 router setup on said pppoe connection.
I will be switching over to a cable connection very shortly.
My question is, what changes do I need to make to the router? Obviously I have to take out the pppoe settings. I will assume I just use the "reset" button on the bottom, but i am unsure.
So, is that how I take out the pppoe settings? And what changes to I have or should add for the addition of cable?
Thank you in advance.
LG
Originally Posted by gitreel
At the very least you will have to change the logon settings the router uses to connect to the internet. I assume with the DSL -> Cable switch you are switching ISPs as well.
Other than that, I doub't anything needs to be changed."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Most DSL setups use that PPPoE garbage. Most cable modem setups use standard DHCP. The little home firewall/router boxes I've used were configured through a web browser and you just selected a radio button for the setting to use.
A man without a woman is like a statue without pigeons. -
Proably just have to change the WAN options to Dynamic IP instead of PPPoE. Most routers have auto-setup feature in the router config. in browser.
N router
By jyeh74 in forum Off topicReplies: 0Last Post: 30th Mar 2012, 21:35 -
Getting A New Router
By Tom Saurus in forum ComputerReplies: 17Last Post: 11th Nov 2011, 16:42 -
Need a new Router.
By Poppa_Meth in forum ComputerReplies: 10Last Post: 29th Sep 2008, 05:50 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 12:34 -
Cisco integrated services router question
By rallynavvie in forum ComputerReplies: 0Last Post: 5th Jun 2007, 09:54
