Hi everybody,
Im using the pioneer a107 (on firewire) and datawrite red DVD-R media.Sometimes , after burning a dvd with nero and trying to play the movies in bsplayer i get an error message .Also in media player i get an error about runtime .I have acces to the disk and can even see the thumbnails of the movies.What can be wrong?the same movies when they were on the hard disk played with no problem at all.Im suspecting the media but happened often lately so i am not sure.any ideas?
Thank you
sorry maybe i wasnt clear.I meant i have divx movies in the dvd and i have problem playing them
here is the error message
BSPlayer v1.00.807, Unhandled exception at EIP: 77E73887
If you click 'Close' application will be terminated.
Please report this info to the author with description what were you doing.
External exception E06D7363
EExternalException
, 0x004E9B4B, 0x004E9D49, 0x004535B3, 0x0044A8FE, 0x77D43A50, 0x77D43B1F, 0x77D43D79, 0x77D44374, 0x004EAC88, 0x77E814C7
weird thing is that the same disk plays ok in other pc.
I have heard that if your FireWire card or on board FireWire is not TI chipset (Texas Instruments) then it may not be completely relyable in WindowsXP.
This is probably the issue, if you want to try other media however, I have always had great test results with this kind. (and they're inexpencive too!)
4x-R or +R $0.59 -
If it plays OK in other pc players, I doubt there's anything wrong with Firewire. I would try it on DIVX player, then try some different media, though it sounds more like a software problem with your computer.
Trouble playing ripped DVD with Windows Media Center 2005-bad country code
By nzdreamer55 in forum DVD RippingReplies: 3Last Post: 6th Mar 2010, 10:28 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Bad DVR-MS files with Vista Media Center
By waxtadpole in forum Media Center PC / MediaCentersReplies: 6Last Post: 13th Dec 2008, 16:50 -
Blu-Ray Media - Who's good and Who's bad.
By SCDVD in forum MediaReplies: 1Last Post: 23rd May 2008, 03:58 -
Bad DVD media
By PhoneMatt in forum Newbie / General discussionsReplies: 13Last Post: 19th Jan 2008, 11:01
