Hello. I just want to know whats exactly "analog pass throu" and how to do it. I have an idea of what it is. And someone knows if the sony dc trv350 or the jvc gr-d31 has this feature?
thanks.
You're probably referring to analog to DV pass-through using a digital camcorder. Some of them have this convenient feature... the lowest priced models usually do not.
For example, let's say you have a older analog (8mm, Hi8, VHS-C) camcorder and tapes. If you want to make copies of the tapes to a digital format, you'll have to hook up the video and audio outputs of the camcorder to some type of device that can convert the analog A/V signals to digital.
Of course, you could make digital videotape copies of the older analog tapes with a MiniDV or Digital8 camcorder. However, some digital camcorders have a "pass-through" feature that allows the converted analog A/V signals from your older camcorder to simply stream through the DV firewire output without recording to tape. This DV Firewire output can be sent to a computer to be captured to .AVI files for editing.
Check the instructions on your particular digital camcorder to see if this is a feature it has. -
Analog to digital pass through allows you to connect an analog source (vcr) to your camcorder and at the same time connect a the firewire output of the camcorder to your pc for transfering video. A great feature to have. The Sony DCR-TRV350 has this feature as I believe most all Sony cam's. Couldn't find whether the JVC unit has this though the JVC-GRD33 does have the feature. I believe the D33 is the successor of the D31. You can find out more info on these cam's at camcorderinfo.com. Hope this helped!
Mark
Digital camcorders that have analog pass-thru & TBC
By djnice in forum Capturing and VCRReplies: 30Last Post: 19th Jul 2020, 04:57 -
Canon HV40 analog/digital pass through?
By stantheman1976 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 30th Jun 2011, 07:23 -
Analog to digital pass through with Sony Handycam DCR- HC65
By Gerald Sr. in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2008, 00:18 -
mini dv analog recording pass
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Feb 2008, 21:42 -
What is the Best MiniDV Camcorder with analog/digital pass-through
By DigitalGuard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 20th Jun 2007, 15:18
