Hey all,
When I built my newest desktop I installed a DDR 2700 512M dimm
Now with older machines I remembered you could not mix 100 with 133 with 166 etc...
What issues are there with putting 2100, 2500, or other 'versions' of these new DDR's in WITH the 512 I already have?
Do these new chips denote speed 2100 vs 2500 vs 2700, etc?
Thanks... new to this new memory technology.
As far as I know the Mobo will default to the slowest clock speed of the memory.
Is there 2500 memory? I thought it was:
2100/266
2700/333
3200/400
and so on to OCing DIMMs.
As far as mixing them it is not recommended but most motherboards will just clock all of it down to the slowest memory in the machine. I think you just need to make sure you aren't mixing completely incompatable memory modules such as ECC or buffered on an unbuffered system, and obviously not SIMM/DIMM/RIMM. -
Thanks for the feedback.... want to upgrade to 1G in a bit and wanted to make sure I did it correctly.
Others have given you the correct answer.
However memory problems are not always obvious, and
sometimes cause random effects. In other words if I
was wearing your shoes I'd trade your current memory
in when buying a new lot. A little extra cash spent = peace of
mind rather than piece of mind. Got me ?
You might get away with it .... but then again ..... you might not. Don't be surprised if sometime down the road you have some strange errors that you can't put your finger on. I have .... and after replacing almost everything .... it turned out to be memory. I wouldn't mix memory on my main system if the data critical.
"No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
Very Mixed Requirements
By juliam in forum Newbie / General discussionsReplies: 7Last Post: 5th Jul 2011, 00:15 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 06:16 -
How to make a mixed DVD
By Baldrick in forum User guidesReplies: 60Last Post: 4th Sep 2008, 14:01 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 07:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 15:31
