Results 1 to 14 of 14
  1. Member MACCA350's Avatar
    May 2003
    Australia
    Hi all,
    I have a DVD-Audio I want to backup
    Its Dual Layer and uses both VIDEO_TS and AUDIO_TS folders
    Now I am guessing that if it were S/L I could just do a ISO read / ISO write in Decrypter. But being D/L in File mode Decrypter only decrypts the VIDEO_TS folder which contains some Video, DTS96/24 and PCM tracks. The hi-res lossless audio MLP96/24 track is in the AUDIO_TS folder.
    Is there a way to decrypt the contents of this AUDIO_TS folder(which is about 3.5GB) and burn it to a DVDR and do the same with the VIDEO_TS folder on another DVDR, would these two discs work?
    Or should I just wait for a D/L Writer and do ISO read / ISO write?
    I have a feeling this may be the only way for a D/L DVD-Audio seen as there is not much video on them to compress.
    Any suggestions?
  2. Hi.
    Alas programs like DVD decrypter, etc CANT decrypt the AUDIO_TS folder as it uses a diferent (and as yet unbroken) type of decryption to Video DVD's.
    YOU CAN back-up the VIDEO-TS part of the DVD, ive done this with Metallica's Black DVD-Audio. This is because the VIDEO_TS part is designed to be played in normal DVD players and therefore I guess uses the original DVD decrption.
    It has nothing to do with it being single or dual layer, if you tried making an ISO image of it , it would fail to play (as would un-decrypted DVD video) discs, this is because the decryption information is on a part of the disc that is uncopyable , uless you want to spend $1000s on 'Authoring DVD-R disks', the DVD-Rs that we all use on here are 'General DVD-R' disks.
  3. Member MACCA350's Avatar
    May 2003
    Australia
    Ok, so at the moment we cant backup DVD-Audio discs (at least not the hi-res audio part).
    Do you think they(being the authors of Decrypter etc.) are looking into cracking the encryption or is this an impossible task?
    thanks for your reply
  4. Banned
    May 2003
    Massachusetts
    It's not IMPOSSIBLE.
    IIRC it's just using a different type of CSS-ish encryption (but don't quote me on that).
    It's more of a "nobody has gotten around to it because it's only in the past year or so that there have been enough DVD-A discs available for anyone to care" sort of thing.
  5. Well..its because DVD-Video CSS was broken so easily that the makers of DVD-Audio really went to town with CSS2 to make it very hard to crack, in fact the release of DVD-Audio was delayed by a year or so just to do this, so while its not impossible that it will be broken I doubt it will happen anytime soon !
    Im sure if you search the web you can find details of DVD-Audio encyption.
  6. Hi all.
    Does anybody know if it's the copy protection that stops the hi-res audio from being "outputed" by the DVD player digital out?
    Or is it hardware related?
    ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
  7. My DVD Audio player can 'output' the multi-chanel pcm audio on digital form, it goes into the digital connection on my amp !.
  8. What's your dvd player, andydd?
    As far as I know, only a handfull of set-tops will output the high-res audio (not AC3 or DTS) via a digital link, and they need to be connected to a compatible receiver (usually of the same brand).
    ddlooping
  9. My player is a Panasonic DVD-Audio..cant remember the model but it the cheapest DVD Video/Audio player, my amp is an oldish Sherwood one.
    I cant see any reason why using pure digital outputs/inputs wouldnt work for DVD-Audio, what would happen if you only had digital ins/outs as some high end equipment has .
  10. Well..its because DVD-Video CSS was broken so easily that the makers of DVD-Audio really went to town with CSS2 to make it very hard to crack
    if this is true why hasn't Hollywood adapted this??
  11. ..for the simple reason its too late now !!..DVD players and DVD-video discs use CSS , you cant go changing discs now coz no player will play them !!
  12. Banned
    May 2003
    Massachusetts
    Gotta love that, right? It's one reason that the MPAA will put their money behind blu-ray. I guarantee it.
    *sigh*
    - Gurm
  13. Originally Posted by andydd
    If you use an old Sherwood receiver and a cheapish DVD player I can guarantee you will not hear the hi-res multi-channel audio.
    You have most likely been listening to Dolby Digital, DTS or stereo PCM.
    http://www.digitalaudioguide.com/faq/dvd-audio/faq_3.htm#What%20is%20audio%20system%20...r%20DVD-Audio?
    Some of the players/receivers that support hi-res multi-channel audio via a digital link:
    - the Pioneer set-tops with "i" in their names:
    http://www.pioneer.co.uk/uk/product_overview.jsp?category_id=222&taxonomy_id=62-84
    "...and high-quality direct device-to-device digital audio transfers happen via the i.LINK Digital Audio Interface"
    They would have to be used with the Pioneer receivers with also "i" in their names: http://www.pioneer.co.uk/uk/product_overview.jsp?category_id=405&taxonomy_id=62-98
    "Digital-to-Digital transmission via i.link with PQLS" - proprietary link not compatible with other brands (as far as I know)
    - the new Panasonic players and receivers (no support for SACD):
    http://www.highfidelityreview.com/news/news.asp?newsnumber=18868399
    Digital Audio via HDMI link - should be compatible with other HDMI equipped set-tops/receivers.
    - Recent Denon models - DVD-5900 - AVR-5803 - AVR-3805.
    http://www.usa.denon.com/catalog/products.asp?l=1&c=4
    http://www.usa.denon.com/catalog/products.asp?l=1&c=2
    Using "DENON Digital Link" - proprietary and not compatible with other brands.
    This is why all multi-channel DVD-Audio/SACD players have 5.1 analog outputs.
    ddlooping
  14. P.S: to answer my own question, it does look like it's a hardware issue and has nothing to do with copy-protection.
    ddlooping
