test![]()
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
test
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
dodge
You have to give it a full filename if its an image you uploaded with the message. its needs the .jpg or .gif on the end.
If its out on the web somewhere it needs the entire http://yatayata.com/duh.jpg path.
Other then that your on the right path. -
Thanks, this is a html file, but as it seemed to act like a gif, I thought I'd try it out. Any ideas how I can put a html file on this forum? I do not have a web site.
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 08:28 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 02:30 -
Need to make test tool to test Dolby
By djai in forum AudioReplies: 0Last Post: 9th Jun 2010, 06:01 -
Test,test amd propus 630
By budz in forum TestReplies: 20Last Post: 1st Jun 2010, 00:46 -
PSP Test Clip: Need someone with a PSP to test for me!
By FulciLives in forum Portable VideoReplies: 5Last Post: 17th Feb 2009, 20:42
