I think i couldn't explain what I need
I am trying to convert SRT to SUP which now using srt2sup with poor quality, dvd-lab does have a nice rasterizing but it makes a file with .SP and .SP1 and .SP2 extensions... I need something to convert them either to BMP or JPG or even better to have SUP...
thanks -
Have you still got the SRT file?
because when you load the SRT file into dvdlab and hit generate it actually makes individual .bmp files in your temp directory (1Mb each subtitle)
well it did on my system using Beta3 (not tried subs on B4 yet)
check out the link in my sig ......
DVD Lab Pro - Import .SSA subtitle problem
By satan999 in forum Authoring (DVD)Replies: 3Last Post: 27th Jan 2011, 08:21 -
DVD Lab Pro - New OS, same location of files = Subtitle generation = crash
By Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 09:56 -
DVD ripped subtitle file conversion
By dbarrett in forum DVD RippingReplies: 2Last Post: 17th Sep 2010, 12:55 -
DVD Lab message: No subtitle stream normal?
By stantheman1976 in forum Authoring (DVD)Replies: 1Last Post: 21st Feb 2008, 12:10 -
DVD Lab Pro Subtitle Mapping issues
By ArtOfLosingMFZB in forum Authoring (DVD)Replies: 1Last Post: 2nd Feb 2008, 21:41
