I am trying to open a movie in virtual dub but when it trys to load I get the message "not supported as it is an ASF file format and microsoft own the patent, although the movie works fine on the pc.
Is there any way to fix this please?
You can't fix this - Microsoft won't allow it. Sorry.microsoft own the patent
What are you trying to do? There could be an alternative way of doing it.
Regards,
Cobra -
I have a movie on my pc that I want to put onto dvd and watch on my tv.
So I was using virtual dub to extract the wav.
Thanks for replying. -
I had to do this a couple of nights ago. I'm sure there are better ways to do it, but I just opened TMPGEnc and closed the wizard, then fed in the file as audio and set the audio to top-notch. The file it outputs should be a lot easier to work with.
No audio devices showing up in Virtualdub. ASIO plugin needed??
By greggery in forum Newbie / General discussionsReplies: 3Last Post: 16th Apr 2011, 20:37 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Redesigned Virtualdub needed
By demonwarrior in forum ProgrammingReplies: 11Last Post: 13th Dec 2007, 16:10 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
