I'm using Premiere 6.0 to edit some videos. But when I try to "preview" or "export" my movie clip I keep getting an error message "Disk Full". I'm pretty sure this means that I don't have enough RAM for my computer. Can anyone please tell me what I need to do to allow this issue to be resolved.
Below is my computer info, as well as the movie clip info.
My Computer:
900 MHz
128 MB RAM
40 GB Hard Drive
AMD Duron Processor
XP Home Edition
ProSavage Video card
Video Clip:
42 minutes in length
AVI(file extension)
359 MB(size)
Divx Codec (compression)
sample size - 24 bit
Data rate 141 kbps
Audio
AC-3 ACM Decompressor
Bit rate 224 kbps
Width- 672 px
Height-368 px
Do I have to cut the movie into smaller pieces, with other software and import the smaller pieces one at a time and work with them?
Should I use mpeg software to re-compress the movie even smaller?
Should I invest in a better computer?
Is RAM even the issue here, if so can I temporarily improve it?
"The future belongs to those who believe in the beauty of their dreams"
-Eleanor Roosevelt -
its not the ram. disk full usually means your hard drive is full. go to my computer and right click on your c drive and click properties, and see how much free space you have. you may need to invest into a bigger hard drive. while your pc isnt the fastest around, you still should be fine working with premiere. it will be a little slow, but it will work
Hey there,
I have found that Premeire is extremely picky when exporting. When you export, don't try to change to many settings. When export, click Settings ->Load -> and pick a way to export it. Usually what I do is first export the movie as DVD NTSC, and uncheck the audio only. Then I go back and export the audio as an MPEG (For exporting as DVD, Adobe doesn't let me use any compression for the audio, Hence, the 2nd export is audio only, no video) After this, I still use TMPGEnc to re-encode the video stream to whatever the final project is.
I guess it all depends on what you are actually trying to export. VHS or LD capture? What are you going to convert to? If you list what you are doing I can better answer you. (i.e. how you are capturing and how much room you actually have left on your scratch drive)
In any case, the "Error disk full" is mostly a simple default error message saying that something is wrong that it doesn't like. I already have gotten it when exporting to a completely empty 120Gig HD.
Cheers,
TrixxRemember when the only way to see a movie uncut was to go to the theatre? -
You both may be right about me not having enough HD space. I'm sitting at about 2.8 GB on a 40GB Hard drive, I will go clean out some stuff that I don't need and see what happens.
I'm not trying to export to a medium like a VHS tape or DVD...I'm just making a music video, for fun, and plan to export it as an AVI and maybe toss it on Kazaa.
I like your Idea(djtrixx) about exporting audio and video seperatley, then using TEMGEnc to combine the audio/video together.
If the above information works...Thanks for the help."The future belongs to those who believe in the beauty of their dreams"
I had this problem too with Nero 6...When it asks you your "target destination" in the burning s/w, you have to put down your burner drive, ie "D", "E" or whatever...This then, for some reason, creates a folder that holds the iso files with getting full...Go figure....?
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 22:06 -
Help please RE "Full Range" focus on Sanyo Xacti HD2000
By SchnauzerPup in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 13th Feb 2011, 10:33 -
"data disk" rather than as an "audio disk"?
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 20th Jan 2009, 10:10 -
Fairuse Wizard full version and adware "win32.rabio"
By ricardouk in forum DVD RippingReplies: 2Last Post: 13th Mar 2008, 11:56 -
Can a Sony "full HD" TV (e.g. KDL-40D3500) display 1920x1080 via
By acnurb in forum DVB / IPTVReplies: 5Last Post: 26th Jan 2008, 01:59
