I'm trying to merge all the VCDs to DVD to save space.
Basically I copy the .dat file staright to my hard drive, then I use TMPGEnc's MPEG tools to "Merge" all the files together. The VCD format is NTSC at 29.97fps with 44000KHz (I know I have to covert to 48k khz in order to be DVD compatible).
However, I'm have Audio not synchronize problem when I use TMPGEnc's MPEG tools to merge. Video's Time is exact match as Audio!
Is there a better way to do this? or am I missing some of the procedure?
Thank you for your help!
This guide should help:
http://www.dvd-guides.com/guides.php?category=othertodvd&name=vcdtodvd
Good luck,
Cobra -
Sorry - I'll read more closely the next time!Originally Posted by azukre
I assume that the audio is in sync to begin with, before TMPGEnc touches it. Before trying other packages, you may have to take the .dat to .mpg using VCDGear - this won't take long.
You could try using FileMerger, and see if that does it any better. Apparently, it just uses a simple copy command and should preserve sync. Failing that, I spotted this package that may help:
https://www.videohelp.com/tools?tool=409#comments
I haven't ever done this before, so I don't know much I'm afraid. With any luck one of these tools will get the job done.
Best of luck,
Cobra
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
Audio & video out of sync
By gaboone in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2011, 22:21 -
Funky Audio & Video Sync Problem [FRAPS]
By Sniff211 in forum Video Streaming DownloadingReplies: 12Last Post: 7th Jul 2010, 10:05 -
Audio out of sync, Batch DVD Steam Converter & Muxman
By assman24 in forum Newbie / General discussionsReplies: 3Last Post: 5th Dec 2008, 17:25 -
Pioneer Plasma PDP-434CMX & Panasonic DVD-S100EG-S sync problem?
By stieven in forum DVB / IPTVReplies: 2Last Post: 18th Feb 2008, 09:26
