I am having problems burning dvd video files backed up from original dvd's. It will burn fine until i reach 90-99% completion. I am using nero 5.5, it came with my dvd burner. Also i have tried recordnow max, same problem. I also tried imgtool burn, same problem. I have updated my aspi driver, no help. Below is the log file from nero:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 10:03:20 AM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 6/25/2002 8:34:54 AM
Nero Version: 5.5.10.4 (Nero Express)
Recorder: <MATSHITA DVD-RAM LF-D310>Version: A126 - HA 1 TA 1 - 5.5.10.4
Adapter driver: <atapi> HA 1
Drive buffer : 1024kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <HP CD-Writer+ 9300>Version: 1.0c - HA 1 TA 0 - 5.5.10.4
=== Scsi-Device-Map ===
DiskPeripheral : QUANTUM FIREBALLlct20 20 atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD800BB-32CCB0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : HP CD-Writer+ 9300 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : MATSHITA DVD-RAM LF-D310 atapi Port 1 ID 1 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 639MB (654640kB)
Free physical memory: 292MB (299536kB)
Memory in use : 54 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: On
11.6.2004
UDF/ISO compilation
7:29:00 PM #1 Phase 112 File dlgbrnst.cpp, Line 1649
DVD-Video files reallocation started
7:29:01 PM #2 Phase 114 File dlgbrnst.cpp, Line 1649
DVD-Video files reallocation completed (no file modified)
7:29:01 PM #3 Text 0 File Isodoc.cpp, Line 7328
Iso document burn settings
Determine maximum speed : TRUE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
7:29:01 PM #4 Phase 111 File dlgbrnst.cpp, Line 1649
DVD-Video files sorted
7:29:01 PM #5 Text 0 File Reader.cpp, Line 115
Reader running
7:29:01 PM #6 Text 0 File Writer.cpp, Line 123
Writer MATSHITA DVD-RAM LF-D310 running
7:29:01 PM #7 ISO9660GEN -11 File geniso.cpp, Line 4546
First writeable address = 0 (0x00000000)
7:29:01 PM #8 ISO9660GEN -11 File geniso.cpp, Line 4546
7:29:01 PM #9 Text 0 File Burncd.cpp, Line 3799
Turn on Disc-At-Once, using DVD media
7:29:01 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 670
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 2120432 (2120432) = #2120432/471:12.32
relocatable, CD pos for caching/writing not required/required, no patch infos
7:29:02 PM #11 Text 0 File DlgWaitCD.cpp, Line 203
Last possible write address on media: 2298495 (510:48.45)
Last address to be written: 2120431 (471:14.31)
7:29:02 PM #12 Text 0 File DlgWaitCD.cpp, Line 208
Write in overburning mode: FALSE
7:29:02 PM #13 Text 0 File DlgWaitCD.cpp, Line 1452
Recorder: MATSHITA DVD-RAM LF-D310;
CDR code: 00 00 00 00; CD manufacturer unknown
ATIP Data: ?
7:29:02 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 822
Prepare recorder MATSHITA DVD-RAM LF-D310 for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 47984640
7:29:02 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 670
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2120432 blocks [MATSHITA DVD-RAM LF-D310 ]
7:29:02 PM #16 Phase 28 File dlgbrnst.cpp, Line 1649
Speed measurement started
7:29:02 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 1963
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
7:40:09 PM #18 Text 0 File WriterStatus.cpp, Line 115
<MATSHITA DVD-RAM LF-D310 > start writing Lead-Out at LBA 2120432 (205AF0h), lenght 0 blocks
7:40:09 PM #19 Text 0 File ThreadedTransfer.cpp, Line 219
all writers idle, stopping conversion
7:40:09 PM #20 Phase 29 File dlgbrnst.cpp, Line 1619
Speed measurement completed: 4.6x (6,348 KB/s)
7:40:09 PM #21 Phase 36 File dlgbrnst.cpp, Line 1649
Burn process started at 1x (1,380 KB/s)
7:40:09 PM #22 Text 0 File ThreadedTransferInterface.cpp, Line 1963
7:40:09 PM #23 Text 0 File DVDR.cpp, Line 1214
Recording mode: Sequential Recording Mode
7:40:09 PM #24 Text 0 File Mmc.cpp, Line 17136
Set BUFE: supported -> ON
7:40:09 PM #25 Text 0 File Cdrdrv.cpp, Line 7429
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 30000 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
8:31:16 PM #26 SCSI -400 File Cdrdrv.cpp, Line 1400
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x02660000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x03
Sense Qual: 0x01
CDB Data: 0x2A 0x00 0x00 0x1F 0x52 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF1 0x00 0x04 0x00 0x1F 0x51 0x70 0x0A
0x00 0x38 0x00 0x00 0x03 0x01
8:31:16 PM #27 DVDR -400 File Writer.cpp, Line 331
SCSI Target error
8:31:16 PM #28 Text 0 File ThreadedTransfer.cpp, Line 219
8:31:16 PM #29 Text 0 File ThreadedTransfer.cpp, Line 213
conversion idle, stopping reader
8:31:16 PM #30 Phase 38 File dlgbrnst.cpp, Line 1649
Burn process failed at 1x (1,380 KB/s)
8:31:16 PM #31 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=6.2.0.132 , size=24698 bytes, created 10/22/2003 9:15:02 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/17/2002 9:05:10 AM
File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 8/23/2001 12:00:00 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
This has got me stumped. I was able to burn dvd's all day long until recently. Also the media that i am using is not branded, but it's the same media that i have used for awhile with no problems.
Thanks in advance.
Results 1 to 9 of 9
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078 -
try uninstalling your nero burn then use NERO CLEAN TOOL, then reinstall nero again. here's the link for NERO CLEAN TOOL: http://www.nero.com/us/631940828445001.html
What brand of dvd media are you using?
__________________________________________________ ___________
I will try the nero clean tool, as far as the brand i have no idea, they are white on the top and a purple color on the bottom. They came in a generic spindle with no brand name. I got the media from tiger direct, that's about all i can give on the media brand.
Use DVDINFOPRO or DVD IDENTIFIER to find out the media code and the manufacturer of the disc. It could be the media that is causing the problem.as far as the brand i have no idea, they are white on the top and a purple color on the bottom. They came in a generic spindle with no brand name. I got the media from tiger direct, that's about all i can give on the media brand.
budz, i tried both programs you suggested and my drive dose't support the feature to get the manufacturer of the media. so i am back to square one.
are you putting the disc in your toshiba dvdrom or dvd burner?i tried both programs you suggested and my drive dose't support the feature to get the manufacturer of the media. so i am back to square one.
I am using the burner to see what the media is.
try using your toshiba dvdrom to read the disc or have you tried that already?
Yes i tried the toshiba, and it just keeps scanning the disk.
AVI on CDRW stops playing in DVD player?
By leonk in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2012, 22:53 -
dvd ripping stops
By jbd441 in forum DVD RippingReplies: 1Last Post: 12th Mar 2012, 20:19 -
DVD Playback Stops then Restarts.
By PowerFalcon in forum DVD RippingReplies: 9Last Post: 2nd Jul 2011, 10:11 -
DVD Shrink stops working
By guamfrank in forum Newbie / General discussionsReplies: 6Last Post: 17th Oct 2008, 01:05 -
DVD Decrypter stops after 1st cell
By MeInNYC in forum DVD RippingReplies: 2Last Post: 25th Dec 2007, 12:59
