Using the default setting "Bottom field first (Field B)" to convert a captured avi to a DVD complient mpg, the result was jerky motion when played on a DVD player. It played fine on the computer. The problem was fixed (I think) by changing to "Top field first (Field A)". But when I encoded using VS7 and "Frame Based Field Order A", the result was jerky, as it was when I used Frame-based, but was fixed using "Field order B". Does Ulead and TmpGenc use A to mean B and vice versa? Any ideas what is going on?
Also a quality and speed question about TmpGenc. I am encoding TV episode captured to avi (352x 480) from cable. I want to convert with VBR 3800 k/s to fit 2 hours and 20 minutes to a disk. Anyway, my results have a little snow which is cleaned very well with the included TmpGenc noise filter. But it takes 4 times as long as without the filter. Is there anyway to make this faster?
Results 1 to 1 of 1
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 04:12 -
upper field or lower field first? how should I export from premiere
By phpmysql348 in forum EditingReplies: 2Last Post: 6th Sep 2008, 23:54 -
Top Field First to Bottom Field First
By boblin2 in forum Video ConversionReplies: 0Last Post: 6th Dec 2007, 00:19 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14 -
About TMPGEnc judging field order
By jmayme in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2007, 14:56
