Any recommendations from online sources. I know I should try to avoid riteck with this burner.
GuestGuest
Not specifically, I'll need to check out what's at home, but I can tell you with the 1300, I have had no problems with Memorex, TDK, or FujiFilm. I will be testing some Sony's soon. My 1300 has 1.0a firmware..... factory.
depends how much you want to spend on the disc? cheap disk and work well... or good disc and last you while for it?
Ritek G04 good disc but expensive (you could find them on many onlines companies like www.shop4tech.com, www.meritline.com, www.rima.com and so on)
Matrix (www.shop4tech.com) cheap and work good
Digital Matrix (www.meritline.com)
all of above product will work will for you on your drive. -
I've used Ricoh's (over 40 of them) and not had 1 coaster, using the NEC ND-1300A. I primarily burn Ritek G04's though, but Ricoh are the only DVD+R I use, on the rare occasion I need to burn +R instead of -R. Either one is great for me though, using the firmware it shipped to me with, 1.06.
GuestGuest
NEC says that the only approved Ritek media is L19.
L19 is the serial listed on the tiny text around the hub (something like H4-3L19305164889D00)
H is the factory, 4 is the floor, 3 is the line. I think 30516 is the date code 2003/05/16. BTW, this was the code from a coaster
L19 is the dye type, so all G04 should be L19.
C 1300 disc is dirty error on NEW blank dvd's
By rrtbusa in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd May 2010, 08:25 -
Hauppauge HVR-1300 and Virtualdub Cannot Capture
By JonnyAlpha in forum Capturing and VCRReplies: 5Last Post: 13th Feb 2010, 09:39 -
NEC TV to Pioneer DVD not working well
By Prasanna in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2008, 04:19 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 21:07 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 13:13
