I've looked thru the forums and am suprised nobody else has had this problem. I got my first VHS recorder in 1984. I didn't upgrade to a Hi-Fi VHS until a couple of years later. I'm getting rid of all the stuff I taped back then and transfering what I need onto DVD. On several of my early tapes, the sound is muffled. I know I can take the audio and bump it up a bit in an audio editing program, but then it get's really hissy. My question: Is there a way to get a better sound without the hiss? I realize based on the original source, I'm not going to get cd quality sound, but is there a way to make it listenable?
	I would use Gold Wave. Load the original video into it, select Effects-->Volume to increase the volume to you liking.
 This is where it gets a little tricky. Select Effects-->Filter-->Noise Reduction-->Presets-->Remove Hiss.
 It won't give CD quality, as you mentioned, but it will be listenable.
 Hello.
  Bad Vhs transfer in digital as sourceBy mammo1789 in forum RestorationReplies: 15Last Post: 4th Nov 2011, 22:04
  vhs video capture bad soundBy lulu15 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2011, 21:59
  VHS-->DVD, "action scenes" and bad sourcesBy Jdrive in forum Capturing and VCRReplies: 7Last Post: 13th Oct 2010, 01:09
  No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad EverythingBy koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48
  VHS/ DVD Go-Video problem. Bad video, good audioBy Shempp Ranger in forum Newbie / General discussionsReplies: 3Last Post: 14th Apr 2009, 21:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
