Does anybody know how to make a good gun shot effect? I'm using Adobe After Effects.
Results 1 to 10 of 10
i as well would like to know how to make a muzzle flash and have a little dust poof of where bullets are hitting... i really need to learn to do this as my movie that im making with some friends has lots of shooting
-mercSYSTEM SPECS:
: Abit NF7-S v2.0:
: Corsair 512MB XMS DDR3200 :
: AMD Athlon XP 2600+ at 2.01 :
: 80 GB WD HDD 8MB Cache :
: Antec LANBOY Case 350w PSU + 2 80mm fans :
: Sapphire ATI Radeon 9800 Pro 128MB :
: LiteOn 4x DVDR/RW : -
Particleillusion 3 has pre-made emitters to create both of these effects.
Boda -
well you have to buy particle illusion 3... what can i do using after effects and after effects only to get gunshot dust poofs and muzzle flashes?
-mercSYSTEM SPECS:
: Abit NF7-S v2.0:
http://www.matthawkins.co.uk/modules.php?op=modload&name=News&file=article&sid=36&mode=thread&order=
or (better in my opinion)
http://www.4bitterguys.com/rants/gun/
both are using premiere i think... you can probably use a similar method for after effects.
On second look... the second link would be very easy to do in AE (and give better results). Simply make your muzzle flashes in Photoshop (or other paint program), and export them with a transparent or black background. Then in AE, have them appear (as a layer on top of video) for a frame or two while the gun is "shooting".-mojo-
http://mpmediaproductions.tripod.com (old site with stuff)
http://www.mpmediaproductions.com (official site, being designed)
http://www.paulinasdesigns.com (current project) -
how do i make particles in after effects? i just want a simple dust poof...
-mercSYSTEM SPECS:
: Abit NF7-S v2.0:
I've done similar effects (and even transporter effects) using Virtualdub and a simple static jpg.
I simply apply the logo filter to the scene with the gunshots, load the jpg, and have a quick fade-out. The instant appearance of the jpg makes it look like a flash, then the quick FO makes the flash "dim".
Same with the transporter, but variable duration fade in, then splice in the actual person's scene. -
You would have to play around with Particle Playground, an effect in AE Pro. It's hard to use (and i've never used it), so i can't help you much.[/quote]how do i make particles in after effects? i just want a simple dust poof...
-merc
BTW, i'm pretty sure particle illusion is coming out with a plug-in for AE. If not, check out Trapcodes Particular an AE plugin that is very similar to PI.-mojo-
Buy Particleillusion 3. It's not that expensive & you'll be glad you did, especially if you are looking for these types of effects.... fire, smoke, dust, clouds, etcOriginally Posted by rbmerc
The other one to look at is AlamDV, which was original designed to do light saber and muzzle flash effects. Different to particle illusion in approach, but also very cheap with a lot of downloadable effects.
Machine-gun audio in avidemux for mpeg2/vob files
By resloan in forum EditingReplies: 2Last Post: 26th Jan 2011, 18:39 -
16:9 shot, but 4:3 in DVD Architect.
By zovx in forum Authoring (DVD)Replies: 25Last Post: 14th Oct 2010, 08:46 -
automatic shot by shot video cutter
By monks19 in forum EditingReplies: 4Last Post: 26th Oct 2009, 19:17 -
What shot is this called?
By Chippy in forum Newbie / General discussionsReplies: 4Last Post: 17th Apr 2009, 23:47 -
Shot in HD - burn to standard DVD
By revlis in forum Video ConversionReplies: 1Last Post: 6th May 2008, 21:56
