I have a dvd-rw disc that I've been using to try out my dvd's b4 burning them to disc, is there any reason why I should'nt be doing this? also even though the disc plays in my dvd player when inserted into my pc it shows no disc and when I check the properties it says file system RAW and the dvd-rw as a CD.
Any1 any ideas?
Do you have any software installed on your PC for playing DVDs?
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
I use canopus which usually plays the dvd in w m/player 9 if I ever try the produced mpeg.
Forget Windows Mediaplayer. It is trash. Unless you are creating files specifficly for it and absolutely have to have it, do yourself a favor and just uninstall it from your system.
For real."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
I got nero vision express as part of nero burning rom but uninstalled it because I did'nt really like how it took over my icons and stuff, is it worth putting back on I think theres a dvd player on there.
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 08:19 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
