I have a Powerbook G4, OS X.2.3 laptop.
After re-orienting my DVD drive to read different region-coded DVDs only 5 times, DVD Player and my DVD drive locked my computer into playing only discs from Region 0 (all-region) and Region 4 (Latin America).
This sucks because it's my legal right to view any DVD, and I buy them from all over the world.
My Desktop G4 allows VLC software to play as many DVDs of different region codes as I like. But I started using VLC on my desktop before DVD Player re-oriented for the 5th time.
How can I cure my laptop and get VLC to work on any DVD?
I tried completely wiping the hard drive and reinstalling Mac OS X plus all the software with no luck.
Am I totally screwed?![]()
I think there is a utility out there, I'm sure someone else will respond with name and link.
You can also rip your non-region 4 discs to your hard drive for viewing. Mactheripper 2 will do this for you ... Around 30 minutes for a full dual-layer DVD on my 667Mhz TiBook. MTR doesnt need Apple DVD Player to get the key off the disc, and your rip will be region free. -
Not sure what drive you have in there but go look at http://forum.rpc1.org/ and look at the downloads section on the home page you will need to know the drive specs so you know what to flash it with.
G4 gigabit,PL1.35GHz,
Radeon 9800 Pro 128,1.5GB ram,Pioneer dvr 107D,Running on tiger. -
How did you go mate was the info that you needed there?
YAY!
Yes cynikal's firmware that I found there worked like a charm.
I'm so happy!
YAY! YAY! YAY!
Thanks a lot, mate! Are you from Australia or Britain, g4Cube? Cool, mate! YAY! -
I am from Sydney Australia mate.
How do I reset video settings on my Lacie LaCinema Classic drive???
By neilharris76 in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2011, 19:25 -
How to reset the DVD drive region code?
By coody in forum DVD & Blu-ray WritersReplies: 13Last Post: 17th Apr 2010, 04:42 -
DVDRW drive cant read DVD Movies - Is it Region Locking or ... ?!?
By quantass in forum DVD & Blu-ray WritersReplies: 7Last Post: 8th Apr 2008, 23:45 -
dvd drive cant read cd
By d_unbeliever in forum ComputerReplies: 4Last Post: 20th Feb 2008, 01:43 -
XBox 360 HD Drive and HD-dvd - regions?
By elfranko in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th Nov 2007, 12:15
