I finally got a certain video to burn for a VCD. Someone told me to download some thing(I forgot the name of it) but I used Nero and it finally added to the video files. So I used a CD-RW and I only burned the one video and I put it in my DVD player, and it played the video, but there was NO sound! I FINALLY get this thing to 'work' and it has no sound. Does anyone know how I can fix this?? Thanks! I need help!
Well, before anyone can fully answer your question, I have question too. What kind of video/audio file(s) did you make? MPEG or other? What software did you use to make the video/audio data?
My the file is an mpg.
and my online friend gave me "Nero MPEG2-DVD Plug IN" and after I downloaded that, the video finally added to the video files. It didn't before. -
I downloaded VCD easy and it said the video wouldn't work for a VCD. I tried it for a SVCD and it added the file but said there might be playback problems. So I Burned the video on a cd still using VCDeasy and the video was distorted so was the sound. This is so annoying. Can someone maybe fix the video on a program and send it back to me on AIM or something? Cause I'm obviously not having luck with it. Maybe someone can do it for me. I would REALLY appreciate it. My aim name is Sparkeystar185 Thanks.
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
