ok .....i have been ripping and creating all types of digital files for a long time now but i am totally stumped by this...maybe someone that knows a fix or idea has a fix.....i capture from my tv card to huffy video and wav audio....resulting avi plays perfectly in sync......then i strip the audio from the file to make a wav.....then i framserve from vdub to tmpgenc to make xsvcd (all latest versions) while i encode the audio at the same time inside tmpgenc with toolame......the audio is always out of sync after the conversion - all audio files are 44.1 khz and are never changed from that - what is the cause of my problem? i should note that i am only using one filter in vdub and it does not give a warning that my file will be out of sync........the same desyncroniztion happens even if i do not split the audio beforehand....and remember, my captured file is in sync
also, even when i try to convert with tmpgenc straight from captured (synced) file (no vdub), the audio still goes slighly out of wack
oh, one more thing to clarify - i capture at 29.97 and convert to 29.97 framerate so that never changes either
TMPGEnc DVD Author 3 gradually loses audio sync
By timmus in forum Authoring (DVD)Replies: 1Last Post: 6th May 2009, 18:24 -
Tmpgenc 3 audio video out of sync before encode
By marioval in forum Authoring (DVD)Replies: 8Last Post: 30th Jan 2008, 15:07 -
Sync Problem when loading into Vdub MPEG2
By ebayer077 in forum Video ConversionReplies: 0Last Post: 2nd Aug 2007, 14:55 -
framserve PGC
By kurbads in forum Newbie / General discussionsReplies: 10Last Post: 3rd Jul 2007, 09:03 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 15:10
