I have the movie The Stand on dvd. It is a single DVD that is double-sided and dual-layered (DVD18). I want to back it up onto a single DVD-R. I Ripped it to my hard drive and tried to run it thru DVD Shrink. The problem i have with that is it won't compress it enough. I have to run each side thru then run it thru together (3 times total). That isn't going to work because it will take too long. I tried DVD2ONE and but i don't want to join the 4 parts into one movie file. The only other option i can think of is to run it thru TMPGEnc and convert it to VCD then burn it. BUT, DVD-Lab doesn't read MPEG-1 files too well. All I get is green thumbnails and a green preview. I want to make my own menus and TMPGEnc DVD Author doesn't set the menus as root. Does anyone have any suggestions?
Unless you want uber crappy results put it on to 2 dvds cause the movie runs 6 hours long,if you really want to get it onto 1 dvd then you can lower the resolution to 352x480/576 and bitrate of around 1500 kbps with 192 kbps sound of ac3 or mp2 using 2 pass vbr.Dvd2svcd works great for this type of project.
I have VCDs that have movies over 2 hours long on it and the bitrate is about 650 instead of the normal 1150. the quality isn't the best, but it works. like i said it is a backup of my dvd.
Try re-encoding the file in MPEG-2 with CCE. I think you can do it with TMPGEnc as well but I've never used it cos of all the negative feedback I got. That way you can keep your mpeg-2 stream in a lower bitrate, since you don't mind the crappy quality. Search the guides for Robshot's method on using CCE and you will get the best quality possible.
Just curious, if you're backing up what's essentially 2 DVDs that happen to be stuck back to back, what's so important about making them one? These days it's less than a buck per disc, you're really gaining nothing.
Well I figured since i put the matrix trilogy on 1 DVD-R, which is a little over 6 hours, I would be able to put the stand on 1 DVD-R. Also, I put all 7 Nightmare on Elm Street movies, which i had on VCD totaling 11 hours 10 min, onto 1 DVD-R.
And that is beneficial how? All it does is avoid popping in another disc, which takes 8 seconds, all for consideralbly DRASTIC degradation in quality.
Yeah, why not just put them all on one T-180 VHS tape running in SLP? That's going to give you BETTER quality than what you're getting with that many movies stuffed onto one DVD.
Now, I'm going out on a limb and assuming you DON'T mean that you have the movies in some other format (like DIVX/XVID) and are putting them on a DATA DVD-R.
I only mention this because lately I've been coaching my friends about DVD conversion and one of them just didn't get why the AVI's he burnt to a DATA DVD didn't work in his Pioneer set-top player. *sigh*
- Gurm
DVD Ripping...DVDShrink, DVD Fab question...
By nharikrishna in forum DVD RippingReplies: 9Last Post: 28th Feb 2011, 05:08 -
Regional Code Question - Insignia DVD player - can't play DVD I ordered..
By LadyDriver22 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 12:08 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 20:06 -
question about multiple titles on DVD using DVD Flick
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2008, 20:47
