in TMPGENC i got that error while convert DIVx TO MPG
DO YOU THINK WHAT THE **** IS THAT ????
it means your divx is broken or corrupt....I bet virtual dub only open the movie until that part....you can try using the source range option to get past the broken part and encode the rest of the movie but you will probably have out of sync....that is another issue.
Try the process again, but avoid using any media player device whilst it is in progress. This was a solution given in a previous post and it worked for me - otherwise do what surfisher said...
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22 -
Need some info on bitrate calculation
By heman28 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 19:18 -
overscan calculation
By cd090580 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jan 2008, 08:14
