Hi,
A pal of mine says that it is always better to download Avi's over Mpeg1's. He says the quality is better. I want to put them on a DVD which presumably means converting them to Mpeg2? Will this degrade or improve the quality of the finished product?
Any other advantages of Avi over Mpeg1?
God... being a newbie is lousy!
Thanks for any help
An AVI can be of several formats, such as DV, DIVX and several others. DIVX can have good video quality at high compression rates and small file sizes and when converted to MPEG2 will have to become quite a bit larger to obtain the same quality.
Generally MPEG1 is a lower quality, such as a VCD.
Nothing will improve the quality, you try to keep it the same. Sometimes you have to compromise quality to achieve a smaller file size.
How to convert RM/RMVB to AVI or MPEG1/2
By kschang in forum User guidesReplies: 112Last Post: 11th Feb 2012, 20:56 -
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
mpeg1 in reverse?
By dullrazor in forum Newbie / General discussionsReplies: 5Last Post: 26th Nov 2009, 13:17 -
avi -> mpeg1 in high quality
By steve1401 in forum ffmpegX general discussionReplies: 5Last Post: 6th Nov 2009, 20:53 -
MPEG1 anyone else?
By peterbuilt in forum Newbie / General discussionsReplies: 30Last Post: 11th Feb 2008, 23:31
