  1. I am going to upgrade my pc at the weekend and about the only thing i wasnt going to change was the graphics card.Saying that though i have some movies on vhs which i might want to convert to dvd in the future and was wondering if my graphics card was able to capture them.
    Its a Sparkle GeForce4 MX440 8*.
    Im not even sure if any graphics cards are able to capture or is it a sepearte card?.
    If im going to by a new card or cards is there an easy way to tell if it will capture VHS.
    By the way the card doesnt have to be too powerful as i dont play games or anything.
    Thanks in advance.
  2. Member Moonstomp's Avatar
    Oct 2003
    Dublin, Ireland.
    maureen,
    A quick google search on the Sparkle - looks like it has "TV out" only. This means you can send a signal from the PC to the TV, but not input a signal to the PC.
    To Capture video (VHS etc) you're going to need another card/device. Check out the "Capture Cards" section listing on the left-hand side.
    There are lots of options to choose from depending on your budget. A cheap solution is a "TV card" which will allow you to connect your VCR, Camcorder etc as well as allowing you to watch TV on the PC. I have a "Pinnacle PCTV" card which costs about STG £40.
    Two excellent sites for further reading:
    www.digitalfaq.com
    www.tv-cards.com
    Happy shopping !
    Moonstomp.
    Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials)
