Hi,
My friend successfully burn my VHS to cd .The problem is I cant play it on my computer.The picture will go flickering like the cd is dirty (although is really really clean).I thought it must be disk problem but I`m wrong. When I`m playing to my standalone vcdplayer, the picture goes fine and no problem at all.
I`ve browse all over posting and I cant find any solution. I also find that AVESQ1.dat (sorry, forgot the spelling) on my cd is bigger that normal vcd movie size.Its around 600Mb while any vcd movie file size only around 200 Mb.
I`ve tried playing my friend`s computer and vcdplayer and I just got the same result.
Any idea where the problem came from? Maybe wrong settings when my friend capturing to cd?...or else?
ale
Download the lastest version of Windows Media Player, it has full support for Mpeg-1 files.
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 10:55 -
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 18:57 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 06:35 -
Is there any free VCD playing software which meets my requirement?
By csh in forum Software PlayingReplies: 11Last Post: 20th Dec 2007, 02:21 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 13:25
