I´m about to install one extra harddrive and a dvd burner on my system and Im not sure which IDE channels to use.
In total I now have one 100 Gb and one 120 Gb hd, both 7200rpm. I have one cd-rw burner and one DVD burner.
Ive got the 100Gb drive with win XP on IDE 0 as master. Where should the rest go? Im planning to use the 120 Gb for video only.
Im sorry if this question has been asked many times before. I have done a search but I didnt find an answer.
Thanks in advance.
Hakster
I just installed a 160gb drive and a dvd burner on ide1 with dvdburner being master and hdd being slave with no problems in burning or file access.
Stick your extra harddrive(make sure it set to slave on the jumper settings) on the same IDE as your master harddrive.
Stick the DVD burner on the same IDE as your Cd-Rw. i'll assume that the CD-RW is set at master, so put the DVD Burner to slave.I Have Always Been Here
Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H -
Originally Posted by marvel2020
I would keep the hdds on separate ide for better transfers between them and same with the cd/dvd drives.
Originally Posted by johns0
Hakster
HD with harddrive?
By Cabal2000 in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Dec 2010, 23:50 -
How to get DVD's on harddrive to TV?
By macamba in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2008, 07:27 -
harddrive to dvd
By woody64 in forum DVD RippingReplies: 0Last Post: 24th Nov 2007, 07:50 -
Dead Harddrive
By mysts in forum ComputerReplies: 2Last Post: 22nd Aug 2007, 16:50
