good day all,
I know this is a video forum, but I am making a picture to go over a dvd I am making, and I have a photoshop question, if anyone is very good with photoshop. how do you take a image and insert to into a shape like for example a circle or ellipse?
thanks for any help.
sincerely,
schunn99,
encoder/learning digital artist.
here's a (sorta) easy way.
- make your shape in whatever graphics program you choose. make it a two-color picture, with a solid color shape against a (different) solid color background.
- use the Magic Wand, select the shape.
- go up to Help -> Export Transparent Image. Follow the prompts. Save as a .png file (supports mulitple levels of transparency).
- open the image you want in the shape. add a new layer on top. cut and paste the .png with the transparent shape on the top layer over your image.
merge the whole thing down, crop to size, do whatever you need to it....- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
New image, with TRANSPARENT background. Draw picture on the square canvas.
Pick the CIRCLE lasso, hold <SHIFT> key so it stays perfect circle. Drag to what you want.
Goto SELECT -> INVERSE. It now selects the stuff you DONT want. Hit DELETE. That other junk is now gone.
Crop down with CROP tool just outside the edges of your new circle.
Save as a PSD or GIF files. PSD suggested for printer use. GIF for web use.
Done.Want my help? Ask here! (not via PM!)
and for DVD use, what would you suggest?Originally Posted by lordsmurf
btw Lordsmurf - happy anniversary. (1 day late)- housepig
Housepig Records
out now:
Photoshop question about printed size, DPI, etc
By sdsumike619 in forum ComputerReplies: 4Last Post: 3rd Oct 2009, 12:16 -
Photoshop question (use layer names as text?)
By sdsumike619 in forum ComputerReplies: 1Last Post: 30th Apr 2009, 19:22 -
Photoshop
By romanstopme in forum ComputerReplies: 4Last Post: 3rd Jun 2008, 23:55 -
Photoshop 2.0
By Tom in HD in forum MacReplies: 13Last Post: 27th Jan 2008, 04:42 -
Photoshop question (applying a transparent layer to multiple psd's)
By Alex_ander in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2007, 09:34
