Tperez2 did check the AVI was there any thing wrong with AVI capture around 29 to 30sec mark?.
I scoop thur the drivers and INF but I don't see any registry entery which maybe self registrying.
But being you only that has the card one way find out is with GraphEdit
then select Graph> Insert Filters the scool down to WDM Streaming Multiplexer Devices dbl click on VerMedia 61051 MPEG Encoder clocse filter box and then rigth click on Filter (VerMedia 61051 MPEG Encoder) go to Filter Properties see there are any option being show.
http://www.shspvr.com/graph_build/download/graphedit_dx9.zip
Results 61 to 90 of 154
Ok I know what mean I just you can't do that but did you check the AVI?.
Actually I didnt realize I would need it I deleted it before you asked me to check it. If you like i can make another capture.
No problem try this tools Handy Recovery http://www.handyrecovery.com/
hope lee can get it back -
Yes now that i know what to look for I can see the block noise in the original file. I am uploading a new capture of a cartoon that seems to be eaiser to analyse
Well I just got done looking at the clip called, "avi2mpg.mpg" and I have a few comments.
First of all the field order was reversed at some point because I don't get smooth playback on my TV from that clip (although I did from the frist clip, "tperez.mpg"). Field order is definately the problem.
As for the image quality ... it seems a bit "grainy" and there are MPEG compression artifacts present.
Using BITRATE VIEWER I'm getting a MAX bitrate of 5815 but an avg of only 3410 (some the low spots are just under 20000kbps) which sounds a bit low for 720x480
So I can't tell if these MPEG artifacts are from the AVI to MPEG encoding step (user should have done 8000kbps to rule that out) or if perhaps they are just part of the source ... bad cable channel reception or too much dish compression etc.
Come to think of it ... didn't Tperez2 say that "movie" channels actually recorded well? Don't digital cable and dish etc. use less compression on "premium movie" channels?
In other words it could just be the source.
Would be interesting if I could get ahold of the original AVI (of this segment) and see what I could do with some AviSynth filters and CCE encoding.
I'm afraid that might tax poor SHS's bandwidth though :P
- John "FulciLives" Coleman
P.S.
Tperez2 ... maybe you can try a capture from a high quality source like a DVD for instance."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Originally Posted by Tperez2
- John "Fulcilives" Coleman"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
That cartoon.mpg was done by hardware encoder FulciLives. -
Originally Posted by SHS
Actually the last clip cartoon.mpg was captured as uncompressed avi and converted with tmpgenc but i selected ntsc vcd by mistake uploading cap2.mpg now same process but sellected ntsc dvd using max bit rate 8000. I will try capturing from svideo port on my dvd player tomorrow. i think we all need a break. but i thank all of you for all your help
Tperez2 that toon2.mpg I just look at it the one he getting is with ducktales
I am now uploading a capture from my dvd player done at 8000 this should answer any questions as to wether the video source is causing my problems
Tperez2 take this this done with PVR 250 from S/Video from my Dishnetwork box with all latest drivers install using SageTV Recorder.
I take look at thoses clip you psot
ftp://ftp.shspvr.com/download/moive_clip/tperez_clip -
can someone post a small clip captured with a AIW so i can see the difference?? The PVR cap looks very good to me.
Originally Posted by Tperez2Want my help? Ask here! (not via PM!)
When you get a chance check out a few frames like you did the first file i sent and let me know what you find. Thanks again
I when thur dvd.mpg and was 100% a ok Tperez2 I didn't see problem what so ever.
You said you where recorder from Digital Cable rigth?, I just wonder what kind S/Video cable are you using.
FulciLives, Tperez2 I know you said look grainy but keep mind that old TV show and movie are usely are grainy in place in there original format.
If he was have grainy then cartoon would show this rigth way -
Using a Monster cable THX V100SV S-VIDEO CABLE I thought if it was THX certified that it would be good enough. Can someone recomend a better cable??
Originally Posted by FulciLives
It's on the server, I verified it.Want my help? Ask here! (not via PM!)
But I am downloading it right now.
At this point I plan to buy an ATI AIW 9800 PRO unless someone has a good reason for me to stay away from this card. I figure with this card in my machine I should have a very good multimedia/gaming machine.
That S/Video cable is really good one I hope you didn't get something like 16' Footer that possable lee can cuase problem being that long I have some what the same type of cable, Then most like what is happing is most likely some of the error your see are most likely coming from Digital Cable Receiver could been build-in decoder or Video DAC output or even bad encoding on there side which is most likey where that error come from in first place like what you scean in that western show and it possable that Andy Griffith show as well.
I had that thing like western show error happing before on my end.
I seat down and recorder from min diff channel with Hardware MPEG encoder then do same AVI capture then Comparison them.
One Good soild way to do Direct Test Comparison is use a Home DVD Player.
On my Dish box some channel look real good where other like my local TV channel look bad and some other channel which are simie ok.
It all most in possable to see in REALtime unless the error more the 3 frame long then you usely see them on TV.
Here are same Example from TechTV and when around with TechTV and Dish about this problem to point where said hell with it no more TechTV recorder I stick with the other channel.
http://www.shspvr.com/images_other/techtv_anime.html
http://www.shspvr.com/images_other/techtv_geneshaft.html
http://www.shspvr.com/images_other/techtv_lastexile.html
By the way what area in USA are you in Tperez2?. -
lordsmurf you call that good a clip even Tperez2 look more soild then this.
I just uploaded a 30 sec capture from my digital cable box from one of the movie channels. its called movcap.mpg please let me know what you think
That last one was a realtime mpeg 2 capture using 8000 kbps and vbr. Can you do a frame by frame like the last one and let me know what you think.
Error message with AverMedia DVD EZMaker
By JeffinPortland in forum Capturing and VCRReplies: 0Last Post: 16th Apr 2011, 17:26 -
HELP please Avermedia A316 Mini PCI-E Analog Digital DVB-T TV Card
By Jorocketoz in forum Capturing and VCRReplies: 0Last Post: 26th Jun 2010, 00:05 -
Unable to transfer some VHS to DVD using AverDVD EzMaker PCI Card
By fromvn in forum Newbie / General discussionsReplies: 4Last Post: 26th Oct 2008, 11:38 -
Cannot Uninstall or Reinstall UltraTV (AverMedia PCI 300 card)
By steve0701 in forum Capturing and VCRReplies: 2Last Post: 27th Mar 2008, 12:36 -
problem with the ati tv wonder pro pci card
By SabbathPwns in forum Capturing and VCRReplies: 0Last Post: 7th Jul 2007, 03:21
