Please help, I am trying to find solution to my problem for the past 2 weeks but so far unsuccessfully. I have AutoGK and SimpleDivX each of which installed its own, I presume, VirtualDubMod (VDM). However, when I try using either of them VDM crashes with "An out-of-bounds memory access (access violation) occurred in module 'ntdll'." I have latest XVid codecs. Does anyone know how I can solve this problem? This happenned to different DVD's that I tried to back up therefore source is not the problem. Please help. Thanks a lot in advance.
Foxconn A79A-S|AMD Phenom 9950 BE|8GB RAM|150GB WD Velociraptor|2 HD4850 in Crossfire|Windows Vista 64 Ultimate SP1
Abit NF7-S|AMD Barton 2500|1GB RAM|3*160GB HD|HD3850|Windows XP Pro SP3 -
Virtualdub mpeg2 can do pretty much the same as vdubmod, worth a try, and better than vdubmod imo.
Originally Posted by thor300Pull! Bang! Darn!
Well, I like easy to use packages, like AutoGK or SimpleDivX since the learning curve for me would be too steep to learn new software, and I am a total n00b to video encoding/editing. Also, I would like to use the latest MPEG4, not MPEG2. So, does anybody know the solution to my particular problem. I've googled a bit and seems to me that tons of people have this problem, however, I could not find even a single solution.
For the sake of people who would have the same problem in the future and use google to find the solution I am posting a reply to my own question. I've reinstalled XVid codecs but it did not help. So, I've installed DivX codecs and now VirtualDub works like a charm. So, if get the same error then most likely your problem is a codec.
my problems were solved by reinstalling another xvid codec.
not every codec is going to work well. -
I worked with the latest XVid codec. It must be that it is full of bugs.
Need help with VirtualDubMod
By Brakiri in forum Newbie / General discussionsReplies: 3Last Post: 17th Dec 2010, 05:28 -
VirtualDubMod crashes at certain output resolutions
By Kylenol in forum Video ConversionReplies: 12Last Post: 29th Sep 2009, 21:54 -
Virtualdubmod
By Irolaan in forum Newbie / General discussionsReplies: 0Last Post: 19th Sep 2009, 12:57 -
About VirtualDuBMod
By YairGOW in forum Video ConversionReplies: 4Last Post: 10th Sep 2009, 16:45 -
AutoGK prob - VirtualDubMod crashes on open
By Djinn252 in forum Video ConversionReplies: 8Last Post: 7th Jan 2009, 10:23
