Hi... I just bought Dazzle creator 80 and was wondering if I can capture in mpeg1 real time... or where I can get a mpeg1 codec? thanx
TMPGenc can do the coding for you ( freeware ) if not get Ligos LSX . none of these are realtimne though . it is nearly impossible to do encoding in realtime on a computer platform
for realtime encoding you need the Dazzel DVCII . This comes with a hardware encoder ( card that plugs into the computer ) or a card like Canopus DV-Rex or Vitec DVM. these things are megabucks thoug !
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Need MPEG1 encoder
By Xpenguin17 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 5th Oct 2010, 11:16 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
MPEG1 anyone else?
By peterbuilt in forum Newbie / General discussionsReplies: 30Last Post: 11th Feb 2008, 23:31
