I've made several backups (Complete Copy) of some DVD's using DVDshrink and they all play fine. My question's are
1. Does DVDshrink remove copy protection like DVDdecrypter ?
2. Should I use first use DVDdecrypter then use DVDshrink ?
If you backup single layer DVD disc to DVD-R then use dvd-decrypter in iso mode. You get exact copy of the disc (with all regions/protections removed).
If you backup dual layer DVD disc to one DVD-R using dvd shrink there it will remove protections by itself, you dont need to first copy the DVD to HDD with dvd decrypter (unless it is your choice - i.e. you want to 'save' your dvd-rom and you want to copy it to HDD before you use dvd shrink)
DVDDecrypter not ripping vobs correctly
By vcd4me in forum DVD RippingReplies: 4Last Post: 16th Jan 2012, 16:08 -
Problem: DVDShrink > DVDDecrypter - Layer Break Issue?
By Dave Stewart in forum DVD RippingReplies: 32Last Post: 27th Jun 2010, 20:18 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
DVDdecrypter region code not set. Help
By X_Splinter in forum Software PlayingReplies: 2Last Post: 9th Sep 2008, 17:08 -
Imgburn Vs DVdDecrypter
By avextraxjp in forum Newbie / General discussionsReplies: 11Last Post: 9th May 2008, 08:17
