ok.. So I got this 5 disc set. I Have this special case which holds 5 discs. The thing is, is this case has a spine 2x as thick as a regular DVD case (its the EXACT size of 2 DVD cases on top of each other).
What method would you guys recommend for printing? should I simply print the cover without the spine and then print a 2nd spine which is of correct thickness and insert the 3 parts (front, spine, back) seperatly? Or should I try something else?
BTW Im going to be printing on letter sized matt paper. Please dont suggest I go buy some Longer sheets of paper.
any suggestions would be great.. Thanks
You could try printing a full insert, but with a wider spine and front. Since it wont fit all the way around, do a second print with the (wider) back.
And don't let anyone tell you that longer is better. It's not the size of thepaper, but how you print it. -
8½x14 paper in a color laser
Oh my.. no bigger papers. I ended up print like the 1st reply stated. I used PS to make the spine wider and leave the front intact and cut off the back. I then printed this so called um 2 piece? Then I printed the back and shoved both inserts inside. Altho at the back you can see a line were the papers cut..it still looks pretty good. thanks.Originally Posted by lordsmurf
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
External case - 3.5 or 5.25 case....
By kenmo in forum ComputerReplies: 3Last Post: 2nd Jan 2009, 16:54 -
Can't print on my CD
By Tom in HD in forum MacReplies: 5Last Post: 19th Sep 2008, 11:33 -
To print labels
By mis3 in forum MediaReplies: 9Last Post: 23rd Dec 2007, 10:27 -
Best way to save/print DVD case inserts?
By stantheman1976 in forum Newbie / General discussionsReplies: 1Last Post: 11th Dec 2007, 14:33
