i kopied badboys 2 (140 min)with dvd decrypter ,dvd2one ,copytodvd
when i play the movie after an hour the movie keeps on hanging
always a few seconds and plays normal ,it repeats itself a couple times
how does it come and how can i fix it
first, check the original disc and see if its scratched. if it is, that could be your problem. otherwise, this is a burning problem. what kind of media are you using? bad media is the cause of most of these kind of errors. try burning at a lower speed and see if that helps.
i would try burning at a lower speed. try 1x or 2x and see if it works
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 17:25 -
DVD-Lab Pro: DVD-R DL burning problems
By jonghyunchung in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 08:57 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 15:34 -
Sync problems while authoring a DVD with DVD Flick
By TioSolid in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 14:21 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 19:00
