Results 1 to 11 of 11
  1. check out this new program! if you have VCD(s) with minor or moderate errors due to scratches, run them through this program. it does a pretty good job as long as there aren't any major gouges.
    http://pressahead.scieron.com/vcd.html
    -mike
  2. Could the data recovery algorithm be used for data discs too?
  3. yes, i actually wrote this software. it's still in beta. if you notice the greyed out "standard video cd directory structure" checkbox... in the next release (maybe tonight) i'll enable the box. unchecking it will make the program copy every file and directory on the disc. i'll make sure to put that in!
    -mike
  4. Thanks for the app. will it work on dvds too? thanks again.
    Or you could just spend $30 on ISO BUSTER PRO and it'll do the same thing. Hard extraction of the data.
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    thank you mike - looks interisting ...
    i believe dvdinfo pro also can do this (not sure) , its not free though ..
    Aug 2003
    north east england
    but why buy a programme when you can use half-eaten nice free programme
  8. ok yeah, go ahead and spend $30. mine is $0 though.
  9. One time I copy a VCD and the CDR had a crack in it you could pull it apart. I used cloneCD it copied it. I also use a Dusc Dr to clean up bad Disk for cleaning
  10. Other then the simple run time error when its unable to access the
    drive (ie no disc) it seemed to work pretty well as far I could tell.
    I'm a programmer as well, so this is not ment as a flame, keep up the
    good work =)
    Sabro
    Print your photos with Foto Copies and CD/DVD/PS2 etc covers with CDX!
    Get 'em at http://www.sabronet.com
  11. I have a VCD that has something wrong that won't allow it be extracted from the disk. I will check this out. Thanks!
