I have a Toshiba DR1 -r/rw/ram dvd recorder from which I can read files on my PC based LG multi-format dvd writer. But if I write a dvd in -rw video mode on my PC, the DR1 rejects it.
The file format on the DR1 is udf v1.02, which is the same as created via Nero on the PC.
Anyone had the same problem and found a solution or refer to any info?
its very likely that it's the media...some dvd players are finicky with certain dvd r's and rw's. I made a few dvd's that would only work in my home dvd player and not in others untill I started using different (apparently better) media. Which stinks cause I spent a good bit on the dvd-r's!
Filter incompatability with older program colorspace
By n4mwd in forum Software PlayingReplies: 4Last Post: 12th May 2009, 10:02 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 04:54 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19 -
Sony DVD+R RW DL AccuCORE incompatability
By dnix71 in forum MediaReplies: 5Last Post: 6th May 2007, 08:54
