Hi,
I used DVD Express to capture home video from VHS tapes via RCA cables.
My system is IBM ThinkPad P4 2.0MHz 512MB and USB 2.0 external HD.
The capture is in NTSC Best DVD (9mbps). The capture is kind of successful, however the bottom 10 lines are shifted to the right side.
Can any one tell me why and how to fix it?
BTW, the device is not warm during the capture process.
Thanks.
First, go to ADSTech and download the Version 3.1 drivers and apps. (watch and make sure you are using the right drivers for your version of device)
Download DirectX 9.0b and install.
Then... disconnect external drive and capture direct to PC (use usb for storage)
HTH
ADS DVDxpressDX2 Audio Disappears during Video Capture
By fjrnut in forum Newbie / General discussionsReplies: 2Last Post: 2nd Oct 2009, 12:53 -
ADS DVD Express DX2 No video capture
By jimbob56nc in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2009, 10:25 -
lost audio after capture on ads tech dvd express dx2
By allan4371 in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2009, 22:03 -
Newbie problem with ADS Xpress DX2
By jimmy_fowler in forum Capturing and VCRReplies: 2Last Post: 1st Jan 2008, 09:09 -
ADS DVD Xpress capture issue 8MM to DVD
By xxnonamexx in forum Capturing and VCRReplies: 1Last Post: 13th Dec 2007, 22:20
