  1. I have all the VOB, BUP and IFO files and can burn with Nero for a DVD.
    Trouble is the subtitles (Dutch) are locked i.e. cant switch them off.
    Can i remove them by leaving out one of the files above and if so which one contains the subtitles.
    Many thanks
    Jul 2003
    Ontario, Canada
    Try load it with DVD Shrink and re-author with unchecking those sub title tabs and then backup. But if you are dealing with a pirated copy, i.e. not original copy of your own, this is not a right place for you.
    Sam Ontario
