Im using the latest ver of TMPGEnc proggy to cut MPEG to splt into two files and the picture quality got worst then the original file. Why? How do I can stop that happening?
You don't make any change except to cut it, and it gets worse quality? Wow, I can't imagine what would cause that. I cut all the time and haven't had that problem. The only thing I can think of is make sure your 'Type' setting correctly matches your file. Once I had it set to Mpeg Stantard when it was actually a non-standard (XVCD) but the result was unplayable, not degraded.
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 21:10 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
bad quality on youtube
By stansvid in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2011, 20:57 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Bad quality downscaling...
By Emillister in forum Video ConversionReplies: 33Last Post: 29th Aug 2009, 12:48
