Before I d/l trial version, I was told that the software is to be used with either Window XP or 2000 but I have Win 98 so will it work with 98? Reason why I try DVD author is to transfer video from DVD-Ram into DVD-R. That's all I need to transfer without any edit, paste or cut.
Thanks!
I use TMPGEnc DVD Author with Win98SE all the time and it works fine. The only limitations are you won't be able to use TDA for burning, you'll have to create your DVD files to hard disk, then burn with another application (I use RecordNow Max.)
And you have to keep in mind 98SE 4GB limitation. Just keep the VRO file on the DVD-RAM under 4GB and you should be alright. -
Thanks Elkfir,
I use DVD-Ram from Panny DVD recorder when doing about 3 hours of shows without quality degrading. I have noticed DVD-Ram has better quality video than DVD-R when doing long show or any sporting events so that's why I just want to transfer video into -R using TDA.
Thanks!
Author/burn software which burns many mpgs in < time than Win DVD Maker
By wetcamelfood in forum Newbie / General discussionsReplies: 2Last Post: 9th Jul 2011, 12:09 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
